14 years agoParrallel Flash Loader
We are thinking about having the following setup in our new board (see attached image for architecture). We want to do this to give use access to the fast parrallel programming capability of the parr...
14 years ago --- Quote Start --- I looked at the PFL and didn't like it. --- Quote End --- An advantage of the existing PFL design is the Quartus programming support. If you don't need it, any other design is as good and most likely better suited for a specific task. The PFL design isn't particularly instructive, but basically understandable if you want to adapt it to your purposes.
