14 years agoParrallel Flash Loader
We are thinking about having the following setup in our new board (see attached image for architecture). We want to do this to give use access to the fast parrallel programming capability of the parr...
14 years agoA special point with the flash data format in a PFL *.pof is the embedded structure information describing start address and block length. It's not present in a standard *.sof or *.rbf file. Apart from this detail and the usual header differences, all programming files are containing the same configuration bitstream, either compressed or uncompressed.
