12 years agooutput to header on DE0-nano cyclone IV E
DE0-nano FPGA identifies header output as example GPIO_2 header JP1 as Pin 5. I have used the DE0-nano FPGA system generator to set the project. I used the .bdf file system to create the cod...
12 years agoThanks.
The pin assignments are also in the user manual. Some time in the past I had used the back annotation and it was wrong. Don't use the back annotator. Had to remove all assignments and reassign. Wrong you must use the back annotation.
