15 years agoOutput Pins stuck at VCC or GND (All of them!)
Hello I am using the Altera PCI-compiler MegaCore in 32bit target mode on a Cyclone III EP3C16F484I7. When I simulated my code in ModelSim (Altera edition), it work perfectly. But when I t...
15 years ago --- Quote Start --- but do all signals used in a process need to be in the sensitivity list? --- Quote End --- All clocks and asynchronous signals should be included. But omitting them causes only problems in simulation, sensitivity lists are ignored in Quartus synthesis, but wanings are issued though. Also the other warnings you quoted won't be expected to cause the reported behaviour. This sounds more alarming: --- Quote Start --- But I also get stuck at warnings for pins that should be functioning --- Quote End --- But as said, the problem may be also due to signals not present in the hardware or not acting as expected.
