15 years agoOutput Pins stuck at VCC or GND (All of them!)
Hello I am using the Altera PCI-compiler MegaCore in 32bit target mode on a Cyclone III EP3C16F484I7. When I simulated my code in ModelSim (Altera edition), it work perfectly. But when I t...
15 years agoThere are several points to check:
- pinout report shows the pin actually connected as intended? - any warnings during compilation about discarded logic or pins stuck? - clock and reset signals applied correctly and with expected polarity
