17 years agoOutput_Pin tming not met in TimeQuest.
Hi I have a problem in TimeQuest. Timing requirement mot met from regster to output_pin. //********************** My .sdc file contain following commands set_output_delay -max 0.2 -c...
17 years agoIt is a quite tight requirement... It depends on what you require. One option is to use a pll to shift the clock that you output, so that it is in sync with your signals.
