greenlantern01
2 years agoOutput HSMC pin via Ethernet port on DE10 Standard FPGA
Hello, I am currently working on a DE10 Standard FPGA along with a DC2390 Daughter Card. I want to get the ADC output from the daughter card (HSMC) and output it via the Ethernet port on the DE10. ...
tehjingy_Altera
2 years agoHi
Sorry I am not very clear what you are looking for.
Are you looking for an example design for the HPS Ethernet Peripheral?
For the HPS Ethernet, if you would like to connect it to other pins you could do it by routing it through the fpga instead of the HPS dedicated IO pins.
You could take a look at the platform designer user guide below if you are unsure on the platform designer environment:
Jingyang, Teh
greenlantern01
2 years agoHi Jingyang,
Yes. I am looking for an example design that I could refer to, to transmit the data from the HSMC port on the FPGA to the ethernet port which is connected to the HPS.
I am currently using DE10 Standard Development Kit (Cyclone V SoC) along with DC2390 Daughter card.
Thank you & Regards
