14 years ago
output GPIO on DE2
Hello I m trying to use the output GPIO on the DE2 board and cannot even get the clock to output. I have pin one out of a breakout board running through a 1k and then to Comm.
My code was immensely simple
GPIO_1(1) <=clock_27;
Is there something wrong? Is there a spefic string of code I need to output anything?
    I figured out my problem. Apparently certain grounds are only for certain pins. I poked around the breakout board and figured this out. .... I learned something today:-P
    Thanks for your time Dave!
    --- Quote Start ---
    --- Quote End ---
    What!? They should not be called ground in that case!
    So I assume this problem was this on the breakout board?
    In hindsight, would you have seen this if you had been probing at the GPIO connector on the DE115?
    Cheers,
    Dave
