14 years agooutput GPIO on DE2
Hello I m trying to use the output GPIO on the DE2 board and cannot even get the clock to output. I have pin one out of a breakout board running through a 1k and then to Comm. My code was imme...
14 years ago --- Quote Start --- I figured out my problem. Apparently certain grounds are only for certain pins. I poked around the breakout board and figured this out. .... I learned something today:-P --- Quote End --- What!? They should not be called ground in that case! So I assume this problem was this on the breakout board? In hindsight, would you have seen this if you had been probing at the GPIO connector on the DE115? Cheers, Dave
