17 years agoOutput amplitute from an NCO
Am i right in thinking that the output amplitutde from the NCO is not constant over different frequencies?
17 years agoHold on...It could be you are having sinc effect of DAC's hold device.
DACs normally have inverse sinc filter to compensate for that. But it could be you are right, as you get closer to Fs the amplitude will droop and becomes zero at Fs(in theory). So there is no problem now. Basically I missed the fact that your DAC is basic without inverse sinc correction.
