17 years agoOutput amplitute from an NCO
Am i right in thinking that the output amplitutde from the NCO is not constant over different frequencies?
17 years agoI am sorry I can't run any projects at the time being.
I suggest the easiest way is to use nios or signaltap(or simulation) after adding this simple piece of code on your sine data:
-- get max data
process(clear,clk)
begin
if clear = '1' then
temp <= (others => '0');
elsif rising_edge(clk) then
if temp < data then
temp <= data;
end if;
end if;
end process; you can use nios to clear temp or read its value per each frequency. Remember to make temp and data signed type
