9 years ago
Oscilloscope, Signal Generator and Altera DE2-115
Hello there,
I am new here, and I would like to know how I can couple an Signal Generator in some input of the board? How can I do this?
And I would like to couple in some output a Oscilloscope, How Can I do that too?
The pourpose of my class work is use a Neural Network to detect a harmonic distorcion implemented on FPGA and to do that I need to insert a input signal and in output see the waveform in a oscilloscope.
Could you guys help me?
Thank you so much.
I
    60 Hz can be well processed by the audio codec (24 bit stereo ADC/DAC with up to 96 kS/s sampling rate). There's some design overhead by accessing the control register through I2C and setting up the serial digital audio interface. You have demonstration projects showing how to.
    In Fact, I want to connect a signal generation ( function generation) on the board, I want want to know how can I do that? The frequency rabge is 60Hz.
    Att.
    Signals in which frequency range? If you're targeting to low frequency up to audio range, the on-board audio codec might be used for signal acquisition and generation. For high frequency range, an AD/DA daughter card would be needed.
