14 years agoOscilloscope , High speed Application
Hi, I am wondering to know if the DE0 nano board will be a good choose for connecting it to an external High Speed ADC (20-30MSPS) and visualize the signal in real time using DSP builder (simulink). ...
14 years ago --- Quote Start --- What cold you said about the memory of the DE0nano in terms of amount of data that can be stored in terms of micro seconds? i.e can I record data up to 6.4935e-05 seconds? --- Quote End --- According to the Terasic page for the DE0-nano, there is 32MB SDRAM. Assuming you can write to the SDRAM at the same rate as your ADC, you can store 32MB of data. If you ADC is 16-bits, then you can store 16M-samples. The total time that 16M-samples corresponds to depends on your sampling frequency. The first thing you need to figure out is how fast can the SDRAM be written to on the DE0-nano. Check out the Terasic design examples, they should have one that uses the SDRAM. Cheers, Dave
