21 years agoOpencores MAC 10/100 Driver
Hi Everyone Please feel free to use these files and/or comment on them. I've written them as a driver for the opencores mac solution. I have been using them with the lwip web server example...
20 years agoNir,
Do you know if this driver works with uCLinux or does it already have a driver? Thanks, Wade --- Quote Start --- originally posted by nir@Jan 4 2005, 04:49 PM hi everyone
please feel free to use these files and/or comment on them. i've written them as a driver for the opencores mac solution. i have been using them with the lwip web server example that comes with the nios ii installation and they seems to work.
i've attached a zip file with three files in it:
opencores_ethernet_mac_regs.h - contains the definitions of the registers inside the opencores mac component.
opencores_ethernet_mac.c and the matching h file is the actual driver.
i've used these files in conjuction with files that come with the nios installation, which i can't post here for obvious reasons. what i did was to make a copy of the altera_avalon_lan91c111 directory, name it accordingly and replace the file in the hal\inc and hal\src as well as the regs file in the inc directory with the file i've attached. i hope this helps someone.
nir
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=3675)
--- quote end ---
--- Quote End ---
