21 years agoOpencores MAC 10/100 Driver
Hi Everyone Please feel free to use these files and/or comment on them. I've written them as a driver for the opencores mac solution. I have been using them with the lwip web server example...
21 years agoHi
The driver I've written works with the ST PHY chip called ST100P. If you want it to work with your device, you'll need to create a file similiar to the ST100P.h file for you device, in which you should define the device's registers. YOu also need to make sure you perform any required changes to make Opencores_Ethernet_Mac.c configure the phy chip correctly (look in read_phy, write_phy and configure_phy functions as in any ither function you think may need a change. I hope this helps. Nir
