14 years agoopencores i2C
Sorry if I am repeating something here, but I have not been able to work with the OpenCores I2C core. I think I somehow get it into Qsys but then I can never generate my system I am assuming because...
14 years ago --- Quote Start --- I have even tried using the OpenCores I2C wrapper found at alterawiki.com/wiki/OpenCores_I2c. The component in Qsys only has 1 or 2 signals, but I am seeing the following errors. It says I must have an associated clock and an associated rest neither of which show up in my Qsys component as available signals. --- Quote End --- That's because the wrapper on the Wiki was created for sopc builder V9.1, not Qsys. You need to change some lines of _hw.tcl file according to Qsys required syntax. I suggest you take a *_hw.tcl file from another Qsys built-in component and use it as a template for your i2c custom component.
