14 years ago
OpenCores 10/100 MAC reports InvalidSymbol
I've built a system with the opencore ethernet MAC connected to the PHY port# 5 of the integrated switch KS8995MA.
I can successfully send packets but received packets are reported by the MAC with the status bit InvalidSymbol. However, a dump of the received frames show that they are correct.
I'm not an expert of TimeQuest and haven't constrained correctly the design: could it explain this?
    Its good to hear that you resolved your receive errors. For me too I found a hardware fault to be the cause of the invalid symbols. A power supply issue with the 2.5V analogue PHY/Magnetics supply was causing transmission errors.
    Ok, thanks for your reply.
    I finally decided to switch to the TSE that I use in 10/100 mode only.
    The board had a hardware issue (RX_ERR was not connected) that make me loose a lot of time, but it works now.
    I have experienced exactly the same problem with 1Gbit MAC. Unfortunately I still do not have a solution. My current theory is that it is because I have not properly constrained the rgmii tx interface. This is not done for you by the MAC.
    I have been able to reduce the number of 'invalid symbols' by changing the output delay on the tx data/control lines relative to the tx clock however I do not really understand why/how this is the case.
    Sorry I cannot offer any advice. I will reply when I get to the bottom of my problem
