OpenCL 2.1 implementation for FPGA PAC D5005
I'm new to installing PAC D5005 on Ubuntu 20.04. I installed Acceleration Stack v2.0.1 including Quartus 19.2 and OpenCL 1.0 Intel FPGA SDK.
(CL kernel(.cl) can be successfully compiled with aoc compiler.)
I'm trying to use SYCL with DPC++ compiler (from https://github.com/intel/llvm sycl branch), but it requires OpenCL 2.1 or higher implementation.
How can I get OpenCL 2.1 or higher implementation for Intel FPGA SDK supports PAC D5005?
Thank you.
- AnilErinch_A_Intel
Hi ,
There are BSPs available which can help in running the OneAPI on D5005.
Please let us know whether using the same resolves the issue.
Thanks and Regards
Anil
- sihong
Unfortunately, I gave up the above installation method.
Instead, I installed OneAPI-basekit and FPGA addon.
I fixed aocl install script due to supported os checking failed(my host OS is Ubuntu 18.04 kernel version 5.4.0).
It works now. Thank you.
Hi ,
Did you consider the interoperability option of OpenCL with SYCL.
Thanks and Regards
Anil
- sihong
Thank you for your reply.
I didn't check the interoperability but, it doesn't seem to answer what I looking for.
The article says not only no mention of Intel FPGA but also the interoperability requires OpenCL-C 1.2 interoperable implementations.
