18 years agoOpen Drain MAX3000A
Hi all,
I plan to use EPM3064 in some app. In old fashion logic, when I need to swing at 9Vdc I use to use 7406 or 7407 gates witch cand be drived by 3.3V and pull-up'ed at 9V for some CMOS logic. I wander if MAX3000A open-drain support pull-up at 9V. Thanks in advance, (somekind newbie in CPLD)3 Replies
the MAX3000A datasheet specifies max. input risetime of 40 ns among recommended operating conditions. You should consider, that the internal logic is really fast compared to HC series. With slow edges, you can easily get doubled clock pulses and similar issues. It is possible, that circuits as you suggested may work with MAX300a, but I wouldn't expect reliable operation. I would use external gates for signal conditioning. Regards, Frank - Altera_Forum
I thought so, thanks.
In fact, I have to use a PWM signal comming from a simple XOR phase comparator (XOR phase comp. due to noise considerations). After LPF I need 0...9V swing so I can use one of MAX3000's XOR gate and use 1 externally OC buffer before LPF. I already have some 7406 buffers as level translators in project. I have one more hardware question: For a signal conditioner, from sine to logic like in image http://www.hcv.ro/signal.gif http://www.hcv.ro/osc.gif Will work in CPLD or I have to use externally HC00 ? Same question if I have to implement a simple XTAL oscillator (of course, only gates inside CPLD). Thanks in advance Edi, - Altera_Forum
MAX3000 can handle up to 5 V input and open drain output voltage. Absolute maximum I/O pin voltage specification is 5.7 V. The intended 9 V would certainly damage the device, you must use an external driver. Regards, Frank
