18 years agoOpen Drain MAX3000A
Hi all, I plan to use EPM3064 in some app. In old fashion logic, when I need to swing at 9Vdc I use to use 7406 or 7407 gates witch cand be drived by 3.3V and pull-up'ed at 9V for some CMOS log...
18 years agoI thought so, thanks.
In fact, I have to use a PWM signal comming from a simple XOR phase comparator (XOR phase comp. due to noise considerations). After LPF I need 0...9V swing so I can use one of MAX3000's XOR gate and use 1 externally OC buffer before LPF. I already have some 7406 buffers as level translators in project. I have one more hardware question: For a signal conditioner, from sine to logic like in image http://www.hcv.ro/signal.gif http://www.hcv.ro/osc.gif Will work in CPLD or I have to use externally HC00 ? Same question if I have to implement a simple XTAL oscillator (of course, only gates inside CPLD). Thanks in advance Edi,
