14 years agoonchip memory timing constraints
Hi guys! I am capturing 1Mbit of 64 bit words at 100MHz with onchip memory on my DE2-115 board. All data is produced on the chip. How do I need to add timing constraints? Do I need to set...
14 years agoOn chip RAM is synchronous SRAM.
You just need to constrain the clock; same as registers. If your constraints are not met , either a) they're wrong or b) Quartus can't produce a design that meets them.
