19 years agoOn-Chip Memory Access
I am currently designing a dual processor system. One of the processors is a NIOS and the other is external to the FPGA and is a Freescale Coldfire. I have a requirement for both of the proces...
17 years ago --- Quote Start --- Hi Paul, You could use dual port RAM if you are planning on simultaneous read/write from coldfire and Nios II. The single port RAM will allow for sequential operation only, i.e., only one master can have access to this RAM at a time. So you can select the RAM configuration (dual port/single port) as per your design requirements. Cheers! BD --- Quote End --- I have the same needs with external processor : I want to instantiate a Dual-Port in SOPC - Data will be written by NIOS or DMA. - Data will be read by external processor. Have you some idea ? regards sebby2000
