16 years agoOdd EPCS Silicon ID Reading
Hi folks,
When attempting to read the Silicon ID of an EPCS64 flash, I start by sending these four bytes (MSbit first): 0xAB, 0x00, 0x00, 0x00. I can see that the EPCS64 drives data on the 32nd clock, but what I read is not the expected 0x16, but 0x08. If I read again, I get 0x20, and once more yields 0x82. It turns out that if I keep reading, this pattern repeats itself forever (i.e. 0x08 0x20 0x82 0x08 0x20 0x82...) Analyzing this a bit further reveals that it's a bitstream with one bit high, five bits low, one bit high, five bits low, etc. I have absolutely no clue why this happens. Hope you can help me out here. Thanks in advance. René Schipp von Branitz Nielsen1 Reply
Something seems to be wrong with your method to interface the chip, either hard- or software. Without knowing the details, the reason can hardly be guessed. Seeing a signature length of 6 instead of 8 (it is repeated by design) suggests some kind of double clocking, e.g. due to signal integrity issues.
Frank
