16 years agoNumonyx StrataFlash Embedded Memory (P30) Conversion Milestone Update
Hello there, I'am using Cyclone III with active parallel configuration in my hardware. In the Cyclone III Handbook is specified that i have to use the Numonyx P30/P33 flash family for AP Con...
15 years agoHi,
i have finished my design, and testing the PC28F256P30TF (BGA Package) in "Active Parallel Configuration" mode too. I use in my design 1.8V core and 1.8V VCCIO with a Cyclone III (EP3C16F484C7). There are no problems with the Quartus II Programmer or the Nios II Flash Programmer. But beware ! The new Flash timing is only supported in Quartus 9.0 and later versions. If you programm the Flash with Quartus 8.1 it will cause a verify error. My Altera FAE told me that the Flash timing is controlled by the Altera "Parallel Flash Loader" (Factory default PFL image). The PFL supports the new Flash timing at Quartus II 9.0 and later.
