15 years agoNumber of reprogramming cycles
I am a beginner in using altera CPLDs. While going through the device handbook of MAX II and MAX V devices, I have seen that number of reprogramming cycles for these chips are limited to 100 cycles. Is it correct or not? Whether I will not be able to configure cpld for more than 100 times?? Xilinx and Lattice are supporting more than 10000 times. Thanks and Regards, Basil Alias1 Reply
--- Quote Start --- Is it correct or not? --- Quote End --- It's a specification. Semantically, it's incorrect, because the number 100 is written under "Maximum" cycles, so strictly spoken, no minimum is guaranteed. I would however expect a typical number of reprogamming cycles of 1000 or more. Practically, an issue could arise with development or prototype boards, because a production board won't be reprogrammed more frequently than a few ten times. With MAX V, the UFM part of the flash memory has got a 1000 cycles specification for the commercial grade.
