8 years agonStatus held low Cyclone IV EP4CE6E22
Hi, I've designed a board with a Cyclone IV EP4CE6E22. I have a problem with the config on the JTAG chain. My device is not detected. I've checked all Vcc (I/O=3.3V, PLLA = 2.5V, VccINT= ...
8 years agoThe package you're using has a GND pad on the bottom of it. Is that electrically connected to your PCB?
From the datasheet: --- Quote Start --- The E144 package has an exposed pad at the bottom of the package. This exposed pad is a ground pad that must be connected to the ground plane of your PCB. Use this exposed pad for electrical connectivity and not for thermal purposes. --- Quote End --- There are quite a few posts on this forum relating to exactly this. Not connecting does cause problems - like yours. Cheers, Alex
