8 years agonStatus held low Cyclone IV EP4CE6E22
Hi, I've designed a board with a Cyclone IV EP4CE6E22. I have a problem with the config on the JTAG chain. My device is not detected. I've checked all Vcc (I/O=3.3V, PLLA = 2.5V, VccINT= ...
8 years agoHi,
Thanks for your reply. 1. I can't test .sof because of my device is not detected. 2. MSEL are tied to GND, nCE to GND, nCONFIG, nSTATUS and conf_done pins with 10k pull-up. For the moment, I just use JTAG configuration with ALTERA USB BLASTER. Because my device is not detected. If I can pass this first step, I will connect the EPCQ4. I 've checked the steps of the link you send me. No result... I've replaced the CYCLONE too and try an other USB BLASTER. The power-up screenshot of the 3 supply 1.2V, 2.5V , 3.3V. https://www.alteraforum.com/forum/attachment.php?attachmentid=15605 Best regards Alain
