Novice JTAG test enquiry
Hi All
First post here.. hope this is the right place. I have accepted a design consultant post for a non-electronics company looking to modernise a system by migrating from discrete components to a Altera CPLDs. Part of my brief has also been to look into JTAG testing of the final circuits PCB for assembly errors. I have trawled the web-site but it is not immediately apparent how to do this. Can you use the STAPL language for example to set pin values via the device's JTAG registers ? Or are there simpler (low-cost) methods to acheive this. Advice or pointers on this aspect greatly appreciated. Paul ------------------------Update 11/11/09 ----------------------- Just came across this web-site offering Free JTAG stuff - www.jtaglive.com (http://www.jtaglive.com)5 Replies
Thanks you for the hint. Jtag.com is known as provider of bodundary scan hard- and software solutions. It's good, that they also entered the basic tool segment. topjtag, that has been mentioned above by grunberg, is also supporting Altera programmings cables and has an attractive price for the full featured tool.
Hi All
I've been keeping an eye on the JTAG scene since my last post and a google alert just brought up this new site. www.jtaglive.com (http://www.jtaglive.com) Looks like they do a collection of basic JTAG/boundary-scan tools including a FREE base-level wiggler for buzzing connections. Even better it works with USB-Blaster I think. Cheers all Paul - Altera_Forum
Many thanks for the speedy responses.
I have checked out a couple of the links and the tools look intriguing but mostly no prices. A bit like the sort of restaurants I avoid ;) . All the best Paul. - Altera_Forum
There are "big" (and usually expensive) boundary-scan tools which can 1) generate test vectors from PCB netlists and 2) allow to develop, debug and run high-level scripts to do boundary-scan testing, clusters (non-JTAG devices) testing and flash programming.
Have a look at: http://www.xjtag.com (http://www.xjtag.com) http://www.jtag.com (http://www.jtag.com) http://www.flynn.com (http://www.flynn.com) www.asset-intertech.com (http://www.asset-intertech.com) www.goepel.com (http://www.goepel.com) http://www.corelis.com (http://www.corelis.com) And there are "small" affordable boundary-scan tools for prototyping and developing which allows to monitor and control pins states. Have a look at: http://www.topjtag.com (http://www.topjtag.com) - Altera_Forum
JTAG boundary scan is rather one element in testing than the universal tool. For this and other reasons, it's typically handled by in-circuit test systems, in combination with other stimulation and signal probe techniques. Also the boundary scan software part is mostly played by the test system.
There are also small boundary scan tools usable in prototyping and development. Also Altium Designer has JTAG boundary scan capabilities.
