16 years agonot compiling
hello all i wrote down this simple divider code and for some reson it wont compile- it gives me the No feasible entries for infix operator "/" thats the code: library ieee; use ieee.st...
16 years agohi,
the divider compnenrt is working well, the thing is that i am tring to put it under another compnenet, the other componenet is using the arith.all library. all the files go throgh complition, but as i am trying to run the testbench on modelsim i get an error saying that "# ** Failure: (vsim-3807) Types do not match between component and entity for port "a". " for all compnenet ports, i have checked both the packege file and the enttity file' where types are defined and they are all set corectlly. do you know i get this error and how can i overcome it? thanks
