m_kumar
4 years agoNot Able to Compile in Windows
I was using Quartus lite edition i trying to run small code but below error was coming,
Error (293007): Current module quartus_map ended unexpectedly. Verify that you have sufficient memory availa...
m_kumar
4 years agoQuartus version 20.1 and windows 10 8 GB RAM
i was targeting Max10 device.
No any other warning/issue
rtl code:
module hw_top ( input wire clock,
input wire areset_n,
output wire led1,
output wire led2);
reg [2:0] reset;
reg [24:0] count1;
wire count1_rst;
always@(posedge clock or negedge areset_n ) begin
if ( !areset_n ) begin
reset <= 3'b111;
end else begin
reset[0] <= 1'b0;
reset[2:1] <= reset[1:0];
end
end
always@(posedge clock or posedge reset[2] ) begin
if( reset[2] == 1'b1 ) begin
count1 <= 25'd0;
end else begin
if ( count1_rst ) begin
count1 <= 25'd0;
end else begin
count1 <= count1 + 1'd1;
end
end
end
assign count1_rst = ( count1 == 25'd24999999 ) ? 1'b1:1'b0;
assign led1 = ( count1 >25'd124999999 ) ?1'b1 :1'b0;
assign led2 = ~led1;
endmodule
