17 years agoNo Cfi Table Found With Stratix Iiep2s180
HELP !
Hi all . " board : Altera Stratix ii EP2S180 FLASH :AM29LV128MH103REI PROBLEM: 1 (When running ) Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x02030828: verified Initializing CPU cache (if present) OK Downloading 00000000 ( 0%) Downloading 00010000 (81%) Downloaded 79KB in 1.0s (79.0KB/s) Verifying 00000000 ( 0%) Verify failed between address 0x0 and 0xFFFF Leaving target processor paused 2 (When programming flash with flash-program shell) Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x02030828: No CFI table found at address 0x00000000 verified Leaving target processor paused i see lots of people met those 2 problems,and i see the suggestions some good people say .but it still do not work fine . At last ,i doubt that the problem must be the address aliginging . Does anyone have met or know the problem of address aligning between cfi (common flash interface ) and flash when using STRATIX II EP2S180's FLASH AM29LV128MH103REI ? AM29LV128MH103REI has two mode ,word mode and byte mode .I use byte mode in my design .AM29LV128MH103REI has 16 data I/O pins DQ0~DQ15 .when you use the byte mode , only DQ0-DQ7 are active ,and the DQ15 is used as an input for the LSB (A-1) address function.And the datasheet say addresses are 22:A-1 in byte mode. shoud i connect like this ?cfi_address(0)-A-1 cfi_address(1)-A0.......(RIGHT ?) BUT ,EP2S180 havenot assign phycal I/0 PINS for DQ15 at all! how can i resolve it ? thanks for everone ! BEST WISHES!1 Reply
This looks like a duplicate post. I would delete this one and focus on the other similar post
