17 years agoNo Cfi Table Found With Stratix Ii EP2s180
HELP ! Hi all . " board : Altera Stratix ii EP2S180 FLASH :AM29LV128MH103REI PROBLEM: 1 (When running ) Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target ...
17 years agothank you ,optikalillusion .I have already tried mthods that NIOS II Flash Programmer ,page 34 said .but it still not work.i am sure the physical connection is okey ,so i narrowed the problem to pin assignments.And the most doubtable pin assignment are the flash address pins.
thanks! BEST WITHES
