13 years agono BSF-File generated with QSYS
Hi there,
...problem with quartus. I use the free web edition and take the nios2/e processor. I created 4 times a system with QSYS. After the generation I want to import the symbol in my quartus block-file, but there is no block from the created system. In the generation-menu "create block symbol sign..." is crossed... I give the whole project names without an space, only whole words... Why does Qsys not generate a block file ? Thank you DE02 Replies
I think i found now the mistake. If you create a softcoresystem with QSYS you have to create first the Nios System with QSYS, before you make something with quartus. After that you can import a bsf - symbol into a BlockDiagramShematic. A BSF_File will generated. At first i create my BlockShematicFile with Quartus and run after that QSYS. No BSF-File ist generated and no Symbol in the BlockDiagramShematic available. Thank you for your answer. Greetings DE0 - Altera_Forum
1) Stupid question : do you get errors before or while generating ?
2) Altera suite uses java, perl, Tcl... So maybe your antivirus or HIPS does sandbox the app. From my experience, Comodo Firewall doesn't like Quartus Qsys and Nios EDS, I had to launch 10 times so as Comodo to accept and remember.
