13 years agono BSF-File generated with QSYS
Hi there, ...problem with quartus. I use the free web edition and take the nios2/e processor. I created 4 times a system with QSYS. After the generation I want to import the symbol in my ...
13 years agoHi,
I think i found now the mistake. If you create a softcoresystem with QSYS you have to create first the Nios System with QSYS, before you make something with quartus. After that you can import a bsf - symbol into a BlockDiagramShematic. A BSF_File will generated. At first i create my BlockShematicFile with Quartus and run after that QSYS. No BSF-File ist generated and no Symbol in the BlockDiagramShematic available. Thank you for your answer. Greetings DE0
