Meisam
2 years agoniosv-download utility unable to download the Nios® V processor application ELF file
Hello, I'm trying to implement HDMI IP Design Example in Quartus Prime Pro v24.1. I got an error during this step: 10. Download the software .elf file using the Nios2 Terminal When I enter this ...
- 2 years ago
Hi
Could you try using the nios2 download command instead of the niosV?
nios2-download / software/tx_control/tx_control.elf -g -r -i 1
Just take not to close your nios uart terminal before downloading the nios2 elf.
Jingyang, Teh
tehjingy_Altera
2 years agoHi
After flashing the sof, you will need to reflash the niosII elf file through the nios2-download command again.
Yes you could, use the latest flow.
Please note that in the latest flow in 24.1 it is using the niosV processor.
The niosV processor is a newer soft processor compared to the niosII.
Jingyang, Teh
