16 years agonios2 ide error message
For a project I am using nios2 ide version 9.1sp2 on windows 7.
When creating an application and BSP from a template I am getting the following error message: ERROR: SOPC_KIT_NIOS2 - Undefined variable When I am looking in the control panel under system variables the variable is set as following: SOPC_KIT_NIOS2 C:\altera\91\nios2eds What can be the cause of this error?2 Replies
I saw the same issue on Altera forum. I guess Windows Vista is creating this problem. Can u pls try to upgrade ur Nios II EDS to version 10.0 and try again? Rgds, Caridee - Altera_Forum
Ressurecting this topic I have the following scenario:
(1) 64 bit - Windows 7 Home Premium; (2) Quartus 9.1 sp2 Searching for similar topics the recommendation is the same: update Quartus to a newer version. But there are no return from the users telling if this was the fix. My questions are: (a) updating Quartus to a newer version is in fact the solution for this problem ("ERROR: SOPC_KIT_NIOS2 - Undefined variable")? (b) if "yes", which version of Quartus is the appropriate for my platform (64bit-Win7Home)? I ask this because the lattest Quartus version can be optimized for Win8 and can have some incompatibility with Win7. Regards
