16 years ago
nios2-flash-programmer failed!
I Desgin a new EP2C8 board with 8MByte flash(S29Gl064N), but it can not download file with nios2-flash-programmer. please help me!!!
it can run Memory Test example and it's OK!
but only nios2-flash-programmer failed!!!
this is output messages:
1. Memory Test
Memory Test Main Menu
a: Test RAM
b: Test Flash
e: FlashErase
m: TestFlash(SHOWMAP, CFI)
q: Exit
Select Choice (a-b): [Followed by <enter>]b
Enter the name of the CFI flash device to be opened,
or just press <enter> to open "/dev/ext_flash"
>/dev/cfi_flash
-Successfully opened /dev/cfi_flash
-Region 0 contains 8 blocks.
-Checking Region 0 for erased blocks.
-Block 1, at address 0x2000 identified.
-Would you like to test this block? (y/n)y
-Starting Flash Test.
-Testing "alt_write_flash" and "alt_read_flash".
pass 1 - passed.
pass 2 - passed.
-Testing "alt_erase_flash_block". passed.
-Testing "alt_write_flash_block". passed.
-Testing unaligned writes. passed.
-Returning block 1 to its erased state.
-Flash tests complete.
-Closing flash device "/dev/cfi_flash".
Press enter to continue...
2. nios2-flash-programmer:# Programming flash with the datafile
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --cable='USB-Blas
ter [USB-0]' --sidp=0x00802010 --id=1524664086 --timestamp=1283755809 --instance
=0 "bit8.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00802010: verified
: Checksumming existing contents
00000000 : Reading existing contents
00008000 : Reading existing contents
Checksums took 0.3s
00000000 ( 0%): Erasing
00008000 (50%): Erasing
Erased 16kB in 0.1s
00000000 ( 0%): Programming
Program failed
Leaving target processor paused
please help me!!!
