14 years agonios2-flash-programmer : elf & sof
Hi all I have a zImage that uses SDRAM. this Image contains an application to configure the ethernet (a default IP address 192.168.10.180) and starts a TCP server when I use nios2 shell: ni...
14 years ago --- Quote Start --- bash-3.1$ nios2-flash-programmer --base=0x02800000 --debug -g Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Found CFI table in 16 bit mode Raw CFI query table read from device: 0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 20: 51 00 52 00 59 00 02 00 00 00 40 00 00 00 00 00 Q.R.Y.....@..... 30: 00 00 00 00 00 00 27 00 36 00 00 00 00 00 07 00 ......'.6....... 40: 07 00 0A 00 00 00 03 00 05 00 04 00 00 00 17 00 ................ CFI query table read from device: 10: 51 52 59 02 00 40 00 00 00 00 00 27 36 00 00 07 QRY..@.....'6... 20: 07 0A 00 03 05 04 00 17 02 00 05 00 01 7F 00 00 ................ 30: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ CFI extended table read from device: 0: 50 52 49 31 33 10 02 01 00 08 00 00 02 B5 C5 05 PRI13........... 10: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Read autoselect code 0001-227E (in 16 bit mode) No CFI override data for [FLASH-0001-227E] Device size is 8MByte Erase regions are: offset 0: 128 x 64K Device supports AMD style programming algorithm Multi-byte programming with 32 byte buffer Sector erase timeout is 16s Word program timeout is 1ms Buffer program timeout is 4ms Starting processor at reset vector (0x02800000) --- Quote End --- it work now :) i can ping 192.180.10.180 but the application don't run (it must be something else) Thank you :)
