14 years agonios2-flash-programmer : elf & sof
Hi all I have a zImage that uses SDRAM. this Image contains an application to configure the ethernet (a default IP address 192.168.10.180) and starts a TCP server when I use nios2 shell: ni...
14 years ago --- Quote Start --- Verifying 001A0000 (98%)assertion "(size & 3) == 0" failed: file "nios2flash.cpp", line 266 --- Quote End --- --- Quote Start --- No is failed :/ --- Quote End --- That verify failure at the end is a known bug. It got to 98% so it's likely OK. If you powerup then try nios2-flash-programmer --base=0x02800000 --debug -g what happens?
