14 years agonios2-flash-programmer : elf & sof
Hi all I have a zImage that uses SDRAM. this Image contains an application to configure the ethernet (a default IP address 192.168.10.180) and starts a TCP server when I use nios2 shell: ni...
14 years ago --- Quote Start --- nios2-flash-programmer --base=0x02800000 uc_flash.flash --verify --- Quote End --- No is failed :/ --- Quote Start --- bash-3.1$ nios2-flash-programmer --base=0x02800000 uc_flash.flash --verify Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Verifying 001A0000 (98%)assertion "(size & 3) == 0" failed: file "nios2flash.cpp", line 266 1 [sig] nios2-flash-programmer 6184 e:\01_Application\Altera\nios2eds\bin nios2-flash-programmer.exe: *** fatal error - called with threadlist_ix -1 Hangup --- Quote End ---
