14 years agonios2-flash-programmer : elf & sof
Hi all I have a zImage that uses SDRAM. this Image contains an application to configure the ethernet (a default IP address 192.168.10.180) and starts a TCP server when I use nios2 shell: ni...
14 years agoIs
nios2-flash-programmer --base=0x02800000 uc_flash.flash --verify successful? You could also add the -g option to test the reset vector.
