14 years agonios2-flash-programmer : elf & sof
Hi all I have a zImage that uses SDRAM. this Image contains an application to configure the ethernet (a default IP address 192.168.10.180) and starts a TCP server when I use nios2 shell: ni...
14 years agothanks for replay,
--- Quote Start --- hen the question is where is your "Reset" vector really pointed too. If it's pointed to CFI_flash --- Quote End --- the reset vector is set at 0x02800000 and the cfi_flash base adresse is 0x02800000 --- Quote Start --- that would confirm your .sof flashing into EPCS is good and MSEL pins are OK. --- Quote End --- Yes flashing .sof into EPCS is good I use convert programming files to generate a .jic then i program the FPGA after i reboot the board and i use nios2-download & nios2-terminal to program zImage it works
