14 years agonios2-flash-programmer : elf & sof
Hi all I have a zImage that uses SDRAM. this Image contains an application to configure the ethernet (a default IP address 192.168.10.180) and starts a TCP server when I use nios2 shell: ni...
14 years agoThen the question is where is your "Reset" vector really pointed too. If it's pointed to CFI_flash, it should work. But if it's pointed to the EPCS (Default setting) it's trying to load the program directly from the EPCS just after the FPGA bitfile.
Pete
