15 years ago
nios2 design help
hey guys can u tel me why .text file wil so big like 16kb-20kb n all .. is there any way i can change settings to make it small..i dont want any special features in my nios 2 design.. im expecting its size to be small. any heads up... pls
    Don't ask the same question multiple times please.
    Try to turn on the compiler "optimize for size" option (-Os)
    i have tried wit reduced drivers and small c. bu stil no great difference.. i wil try others..
    stil how to make it use only criticle drivers.
    how do i know wat driver it should use..
    and wat r optimal stack size for interrupts n exception(r they needed).. im not using any interrupt from my code perspective.
    thanks for reply.... expecting more help..pls
    try thsese setting on System Library Property
    check:
    Program never exits
    Reduced device drivers
    Small C library
    uncheck:
    Support C++
    Clean exit
    also smaller Max file descriptors like 32 -> 4 or so.
    have you tried that?
