17 years agoNios Uart And Dma
HI: I try to transfer datas from uart to onchip memory using DMA,following code is my programme,I use uart assistant to transfer data per 1000m second ,but sometimes I can see the right dat...
16 years agohi,
kind of new in the nios world, trying to use dma with my uart... you wrote : void * rx_buffer = (void*) 0x27000; can you explain this please ? I understand that DMA is a cpu feature, is it a default or I need to add it to my system ? how do you access the the in coming data ? thank you...
