16 years agonios sw development: invalid bmp file produced
Hi, I have encountered a problem while writing to a bitmap file. The code works in the cc compiler but fails to work properly in Nios II IDE. The bitmap file can be written, but the fi...
16 years agoOne possible way around this problem is to write each structure element to the file one at a time.
Another thing to watch out for is endianess. Off the top of my head, I don't remember what endianess NIOS or BMPs use, but you should double check this. If they are different, you will need to take this into account.
