Elyouss
4 years agoNios processor C program
Hello, I'm using the DE0 board from altera and I wrote a little program to toggle an output pin from high level to low level and vice versa. That's my program :
I'm not sure if he contains ...
- 4 years ago
Make sure you're doing the steps correctly as stated in this video https://www.youtube.com/watch?v=joFaxLY-rUE. Based on Generate Completed window line 3, can you check the reason for causing that Failure compiling 'C:/Users/elyes/AppData...'. Alternatively, you can specify the HEX file with QIP.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
Elyouss
4 years agoyes thank you very much and sorry for my late reply
