8 years agoNios ii
Hello, Help Please! I' m new in NIOS II and I try to follow this tutorial in youtube" https://www.youtube.com/watch?v=w82xFo1RNmo" but this error appear : collect2.exe: error: ld ...
8 years agopleaaaase help me
I try to simplify my code just for seven segment but nothing happen in my board . this is my code : # include "count_binary.h" /* Seven Segment Display PIO Functions * sevenseg_set_hex() -- implements a hex digit map. */ # ifdef SEVEN_SEG_PIO_BASE static void sevenseg_set_hex(int hex) { static alt_u8 segments[16] = { 0x81, 0xCF, 0x92, 0x86, 0xCC, 0xA4, 0xA0, 0x8F, 0x80, 0x84, /* 0-9 */ 0x88, 0xE0, 0xF2, 0xC2, 0xB0, 0xB8 }; /* a-f */ unsigned int data = segments[hex & 15] | (segments[(hex >> 4) & 15] << 8); IOWR_ALTERA_AVALON_PIO_DATA(SEVEN_SEG_PIO_BASE, data); } # endif /* static void count_sevenseg() * * Display value of 'count' on the Seven Segment Display */ static void count_sevenseg() { # ifdef SEVEN_SEG_PIO_BASE sevenseg_set_hex(count); # endif } int main(void){ int __attribute__ ((unused)) wait_time; /* Attribute suppresses "var set but not used" warning. */ int count = 0; /* Continue 0-ff counting loop. */ while( 1 ) { usleep(100000); count_sevenseg(); /* * If done counting, wait about 7 seconds... * detect button presses while waiting. */ if( count == 0xff ) { printf("\nWaiting..."); usleep(100000); /* Sleep for 0.1s. */ } } count++; return 0 ; }
