18 years agoNios II Program Counter
Is there anyway to access the Nios program counter from the hardware (instead of using instruction like nextpc..) ? :confused:
You can only read it via the nextpc instruction.
From the NIOS II instruction set reference:
Obviously you can modify the program counter via jump and branch commands. Jakenextpc get address of following instruction Operation: rC ← PC + 4 Assembler Syntax: nextpc rC Example: nextpc r6 Description: Stores the address of the next instruction to register rC. Usage: A relocatable code fragment can use nextpc to calculate the address of its data segment. nextpc is the only way to access the PC directly. Exceptions: None Instruction Type: R Instruction Fields: C = Register index of operand rC - Altera_Forum
Why do you need it? What will you do with it?
If you say accessing it? Is it access in software, or in hardware? Stefaan - Altera_Forum
I already posted the question there 2 months ago but seems no reply so far...:(
Nice question, sorry I can not help you but I can suggest you to post your question to the Nios Forum.
