18 years agoNios II Program Counter
Is there anyway to access the Nios program counter from the hardware (instead of using instruction like nextpc..) ? :confused:
18 years agoYou can only read it via the nextpc instruction.
From the NIOS II instruction set reference:
nextpc
get address of following instruction
Operation: rC ← PC + 4
Assembler Syntax: nextpc rC
Example: nextpc r6
Description: Stores the address of the next instruction to register rC.
Usage: A relocatable code fragment can use nextpc to calculate the address of its data
segment. nextpc is the only way to access the PC directly.
Exceptions: None
Instruction Type: R
Instruction Fields: C = Register index of operand rC Obviously you can modify the program counter via jump and branch commands. Jake
